I recently installed GRASS 4.2.1 on a Pentium 233MMX system running Red Hat
Linux 5.2 . (I downloaded the binary file grass421_linuxbin21.tar.gz from
http://wgrass.media.osaka-cu.ac.jp/grassh/main_linuxbin.html ). I followed
the instructions (linked to from the same page) and everything seemed to go
well. I can start GRASS (by typing "grass4.2") and once I get through the
LOCATION/MAPSET/DATABASE screen (I also downloaded some test datasets), I
type "tcltkgrass&". Here is where the trouble starts. I have tried this
both as root and as a user, but both return the error messages:
Application initialization failed: no display name and no $DISPLAY
environment variable
Error in startup script: invalid command name "bind"
while executing
"bind balloon <Enter> {
set balloonHelp(%W,after) [after 400 {updateBalloonHelp %W}]
(procedure "BalloonInit" line 2)
invoked from within
"BalloonInit"
(file "/usr/local/grass42/tcltkgrass/main/gui.tcl" line 1307)
invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
(file "/usr/local/grass42/bin/tcltkgrass" line 17)
I searched the mailing list archives, but didn't find a problem exactly like
mine, but I thought it might help to set the DISPLAY environment variable
manually:
export DISPLAY=:0.0
This produces the following error messages:
_X11TransSocketUNIXConnect: Can't connect: errno = 111
Application initialization failed: couldn't connect to display ":0.0"
while executing
invoked from within
"BalloonInit"
invoked from within
I also tried "xhost +" (because it was mentioned in an answer to someone
else's display problem in the mailing list archive) but it didn't work,
either.
The binary download page mentioned that I needed the lesstif library, so I
downloaded and unpacked that. It also said I needed the tcltk8.0 linux
library, so I downloaded and unpacked that. I also went to the TclTkGRASS
page and downloaded the latest version there, in case the latest version is
not the one packaged with GRASS 4.2.1. At every turn, I get the same errors
listed above.
I am all out of ideas. If someone could help me get this working, I would
appreciate it greatly. I am running all of this on a Linux partition on my
local harddrive to see if I can make it work. I have access to other
distributions of Linux (SuSE, Debian, Slackware) and I would happily change
distributions if another one would work better.
Thanks in advance for any advice or suggestions,
Linda Moet
Programmer Analyst
GWN Technologies
lindam@gwnsys.ca
