can't start tcltkgrass; DISPLAY error
Hi Linda,
does your machine have a name?
Try
uname -n
to check the situation. If no name is given to the machine,
TclTkGRASS might not work. TclTkGRASS was developed mainly on
Redhat Linux, so it shouldn't cause problems.
Best regards
  Markus Neteler
I recently installed GRASS 4.2.1 on a Pentium 233MMX system running Red Hat
Linux 5.2 . (I downloaded the binary file grass421_linuxbin21.tar.gz from
http://wgrass.media.osaka-cu.ac.jp/grassh/main_linuxbin.html ). I followed
the instructions (linked to from the same page) and everything seemed to go
well. I can start GRASS (by typing "grass4.2") and once I get through the
LOCATION/MAPSET/DATABASE screen (I also downloaded some test datasets), I
type "tcltkgrass&". Here is where the trouble starts. I have tried this
both as root and as a user, but both return the error messages:
Application initialization failed: no display name and no $DISPLAY
environment variable
Error in startup script: invalid command name "bind"
    while executing
"bind balloon <Enter> {
        set balloonHelp(%W,after) [after 400 {updateBalloonHelp %W}]
    (procedure "BalloonInit" line 2)
    invoked from within
"BalloonInit"
    (file "/usr/local/grass42/tcltkgrass/main/gui.tcl" line 1307)
    invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
    (file "/usr/local/grass42/bin/tcltkgrass" line 17)
I searched the mailing list archives, but didn't find a problem exactly like
mine, but I thought it might help to set the DISPLAY environment variable
manually:
        export DISPLAY=:0.0
This produces the following error messages:
_X11TransSocketUNIXConnect: Can't connect: errno = 111
Application initialization failed: couldn't connect to display ":0.0"
    while executing
    invoked from within
"BalloonInit"
    invoked from within
I also tried "xhost +" (because it was mentioned in an answer to someone
else's display problem in the mailing list archive) but it didn't work,
either.
The binary download page mentioned that I needed the lesstif library, so I
downloaded and unpacked that. It also said I needed the tcltk8.0 linux
library, so I downloaded and unpacked that. I also went to the TclTkGRASS
page and downloaded the latest version there, in case the latest version is
not the one packaged with GRASS 4.2.1. At every turn, I get the same errors
listed above.
I am all out of ideas. If someone could help me get this working, I would
appreciate it greatly. I am running all of this on a Linux partition on my
local harddrive to see if I can make it work. I have access to other
distributions of Linux (SuSE, Debian, Slackware) and I would happily change
distributions if another one would work better.
Thanks in advance for any advice or suggestions,
Linda Moet
Programmer Analyst
GWN Technologies
lindam@gwnsys.ca
