Can you replicate the error messages so I can have some idea of what
is going on?
|Hello GRASS People,
|I am working with a shell script which puts up an image and invites the user to
|select a site. The d.where command is used and the output is placed in a file.
|The problem is that I get an error on the stdin ( the mouse button generated
|long lat data ), but only sometimes. This occurs under both of the following
|methods of capture:
This should work fine:
| 1) d.where > file
This is an odd way of doing it, but it should work. I never knew this
syntax was the same as the one above - learn something new.
| 2) cat > file <<eof
| ` d.where `
| eof
| Joseph K. Vaughan
| University of Arizona
| Institute of Atmospheric Physics
| PAS Bldg, Rm 470
| Tucson, AZ 85721
|I can also be reached by return mail on the internet or as
|jkv@air.atmo.arizona.edu and by phone at 602/621-9663.
Michael
