Carto output
Hello,
Are any of you using grass to output high quality cartographic products.
If so, what do you use? I was using ps.map the other day, but I could
not get it to do what I want. I would like my geographic region to be
slightly smaller that the page bounds and to have text in the margin
between the geographic region and the map bounds. Can this be done?
No problem. "Grow" your region so that it is larger than what you actually
want to display, and use a mask to keep raster and vector layers off of that
part of the plot. You can place text using either the text or comments command.
You *will* end up with a border around your entire plot. I usually use the line
command to make a new border around the map. Simply get the corner coordinates
of your mask.
Also, anyone using ps.map with an SGI? The ps file appears to be
incompatible with what SGI wants. I.e., impressario and vstiff do not
recognize the file. I get a psrip error. Any ideas?
Can't help you here. It does generate Encapsulated PostScript.
Thanks.
-Stephen Dzurenko
Ocean Mapping Division
Ocean Technology Center
Graduate School of Oceanography
University of Rhode Island
ph: 401 792-6879
fx: 401 792-6849
e-mail: steve@ocean.oce.uri.edu
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
