cat.c library routine
[followups to grassp]
Is there a way to modify the fprint function of src/libes/gis/cat.c so that
it will print out a dig_cats file in this longer format? Our is there a
simpler UNIX routine to do the same that I'm missing?
Assuming the v.db.rim output format is valid, I would suggest recoding
v.report instead. Alternatively, a quick fix would be a simple shell
script to do something like:
<2:37pm> ~# head -4 test.cat
<2:37pm> ~# set last=`tail -1 test.cat | awk -F':' '{print $1}'`
<2:38pm> ~# set i=0
<2:38pm> ~# while ($i <= $last)
while? echo -n ${i}:
while? egrep ^${i}: test.cat
while? end
redirect everything into a new cat file :slight_smile:
--Darrell McCauley
Original message:
I am using the SCS's v.report program, and it needs a complete category file;
meaning if your highest category is 146, you need to have 146 lines in the
dig_cats file, even if you have no category label for the attribute number.
Example, this dig_cats file;
# 421 categories
Created by v.db.rim
0.00 0.00 0.00 0.00
421:Lake or Pond
has to be written as;
# 421 categories
Created by v.db.rim
0.00 0.00 0.00 0.00
0:
1:
2:
3:
4:
5:
6:
   etc
  etc
   etc
419:
420:
421:Lake or Pond
Thanx for any help!
   Ronald Thomas ^ ront@meeker.cfnr.colostate.edu
    Natural Resource Spec. (GIS) ^
     Resource Management Division ^ Phone: 303-586-3565 x285
      Rocky Mountain National Park ^ 700-323-7285 (FTS)
       Estes Park, CO 80517 ^
