CELL driver resolution problem
Out of interest, how many different ways are there of taking an oversize
graphic and scaling it down to print size, whilst simultaneously increasing
resolution? I am only aware of one method: using the postscript 'save' option
of XV.
ps.map will work quite well for this, as long as you increase the "limit"
variable in map_setup.c to reflect the maximum number of pixels that you care
to allow. The limit "out of the box" is only 1,000,000 pixels for color,
3,000,000 for gray-scale (I never quite figured out the reason for that!). We
changed ours to 100,000,000 pixels - big enough to allow really ridiculus
PostScript files!
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
