I am having a difficult time understanding why the cell files I create in
GRASS are not the size I am led to believe they should be.
I have a SPOT panchromatic image that I loaded into GRASS. I didn't use a
GRASS program to do this. I put he file under /cell, then created a /cellhd
file using all the required data from the SPOT header file. Then I ran
r.support and am able to d.rast the image and create postscript files that
plot out fine. The SPOT file size is equal to the # of rows times the
number of columns (1 byte per cell).
I set g.region so that the entire image fit inside the region comfortably.
I made sure there was no mask set. I then ran r.resample to create a new
cell file.
The new cell file is smaller than what I expected. The region was set to
have 5754 rows and 4613 columns, which calculate out to 26,543,202. The
actual flie size of this resampled file is 25,789,652.
What am I doing wrong? My main goal is to mask out a particular area of the
image (a 7 1/2 minute quad) and create a new cell file (a BIL file) that can
be used in another program. The other program will take a BIL file, meaning
the rows time columns must equal the file size.
Any help and guidance would be greatly appreciated.
