Cell Size Change
Hi, Gary,
I would like to know how to change the cell size of a map. If it is a raster-
ized vector map, must I go to g.region and specify there, then re rasterize?
To change the cell size from 100 to 50, use g.region res=50 , then run
r.resample in=oldmap out=newmap. This will give you a newmap at 50 unit
resolution. This scenario only gives you a new cellfile at 50 units cell size-
the data of course is no better. If you have the original vector file, then
running v.to.rast at the desired resolution will improve the raster file
compared to the old one. If you do not have the original vector file, then
run r.thin followed by r.poly -l to get smoother vector polygons or r.thin then
r.line for converting raster lines to vector. Follow with v.to.rast at desired
resolution. Rick
Rick Thompson- Research Assistant E-mail: rick@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-5736
Ozark Hall Rm. 12 Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
