cleaning up after XDRIVER
In message <32B85D0E.5510@cs.keele.ac.uk> writes:
We use GRASS 4.1 (Spring 1993) Update package 4 under Solaris 2.5
to support some GIS teaching, and the only display devices we use
are XDRIVERs on our Sun workstations.
Students sometimes forget to do
    d.mon stop=x0
and this causes problems when a subsequent user tries to start GRASS,
especially when the XDRIVER process has been killed or otherwise
closed.
I'm not a unix guru, but couldn't you write a script so that when the GRASS user
types 'exit', it runs d.mon stop='open grass windows' before quitting GRASS?
Michael Hanratty Phone: (612) 627-4590
Dept. of Civil Engineering (612) 626-0024
University of Minnesota Fax: (612) 627-4609
St. Anthony Falls Laboratory
Mississippi River at 3rd Ave SE
Minneapolis, MN 55414
if the monitor is not properly closed,
check the 'locks' directory under the GRASS directory.
You should remove the mon.* files that you find there.
      Andrea Giacomelli
      andreag@idra6.iar.polimi.it
      http://idra6.iar.polimi.it:8080/~andreag
      tel: +39-2-23996233 fax: +39-2-23996207
