are there any ill effects of the following command:
find ~grass/data -name ".tmp" -exec rm -rf {} \;
being run on all grass data if grass is not running
anywhere on the system?
--Darrell
--Darrell
In info.grass.user you write:
--Darrell
I assume you are writing this because GRASS creates temporary files
under the .tmp in the user's mapset and some programs leave them
behind. If you are SURE that the programs that created the files
in the .tmp directories are not runinning, then this should be OK.
GRASS will recreate the .tmp directory and and subdirectories when
it needs them.
Michael Shapiro U.S. Army CERL
Environmental Division
P.O. Box 9005
Champaign, Ill. 61826-9005
email: shapiro@zorro.cecer.army.mil
phone: (217) 352-6511 ext 526
fax: (217) 373-7222
