Color Palettes
on??at?Nov?12??95?02?49?17?pm%bnr?ca}?{9511171059?AA22429%sun1?bham?ac?uk}@bnr.
ca>
content-type: text/plain; charset=us-ascii
organization: USDA/NRCS
mime-version: 1.0
reply-to: grassu-list@max.cecer.army.mil
newsgroups: info.grass.user
originator: daemon@ux1.cso.uiuc.edu
grass@sun1.bham.ac.uk (Grass package) wrote:
  The quickest test I would use with r.colors is to take a simple raster map
with a single category and with r.colors do this:
r.colors map c=rules
> 1 brown
> end
Next, look at the rgb value placed for the brown in the $LOCATION/colr/map f
ile.
(brown is 191:127:63)
[stuff deleted]
Alternatively, you probably have a file called 'rgb.txt' somewhere in your
UNIX tree. Do a 'find' to find this. It is a long listing of rgb values
and official color names, like so: 0 0 0 black, and by using a simple 'grep'
script you can select those lines that are of interest to you. or that have
rgb values similar to a known value.
Hope this helps,
      Martijn
P. Martijn van Leusen -------------------------------------------------------+
Leverhulme Research Fellow, The Wroxeter Hinterland Project |
University of Birmingham Field Archaeology Unit |
Edgbaston, Birmingham B15 2TT Phone +44 121 414 5513 Fax +44 121 414 5516 |
E-mail P.M.van-Leusen@bham.ac.uk |
URL http://www.bham.ac.uk/BUFAU/Staff/vanleupm.html__________________________|
Another option. - I use an X utiltiy called xcolorsel to pick the color
I want for my grass colr file. xcolorsel will display the rgb.txt colors,
then you can easily cut & paste into your grass colr file. You can find
xcolorsel on sunsite.unc.edu - It compiled cleanly on sunos.
