colortables and colr2 directory
Lars Schylberg writes:
Today I had some problems with colortables.
My current mapset from grass startup is mapset1
I run d.colors on a raster cell map that is in mapset2.
Then is seems that the valid colormap for this cell map ends
up in "mapset1/colr2/mapset2/cellmap".
I spent over one hour looking for this changed colortable before I found it.
Could someone explain this mystery with the the colr2 directory and if
this is documented somewhere. What is the idea with the colr2 directory.
Since it is possible to have map layers with the same name in different mapsets,
GRASS has to have a way of storing custom colortables that allows this.
Custom colortables for map layers in YOUR mapset will be found under the
directory "colr". Custom colortables for map layers in OTHER mapsets will be
found under "colr2/othermapset" . Once you've got it figured out, it's no
problem!
Malcolm D. Williamson - Technical Assistant E-mail: malcolm@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-5736
Ozark Rm. 214 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
