I execute r.drain and it makes OpenWindows exits(running on my IPX). Other errormessages are:
- Segmentation fault
- Illegal command
Every time it fails a core is dumped.
It sounds like you are running out of memory. I have had problems before (running
our own software) with openwindows crashing when a huge amount of memory is
allocated - not a very graceful way of catching errors !
Get your system administrator to create a larger swap-space and it should then
work properly.
phil
Phil Watson (an ozzie in exile) | _--_|\ | CLUWRR |
phil.watson@newcastle.ac.uk | / \ | Agric & Enviromental Science |
| \_.--._/ | Uni of Newcastle-Upon-Tyne |
Phone: (091) 222 7503 | v | England, NE1 |
