comments desired in r.mapcalc
Steffen...
I am developing some long sequences in r.mapcalc.
I am preparing separate files with r.mapcalc language instructions
and wondered if there is an undocumented method
to place a comment into an r.mapcalc input file, for example,
do_it_to_it.mapcalc
Does anyone have any clever ideas?
Well here's what springs to mind. Its cleverness is disputable.
** I have not tried it. Its just an idea ***
Embellish r.mapcalc with cpp, the C preprocessor and use it to strip out
C-style comments (Use /* to start a comment, */ to end): This is how
the unix command xrdb deals with comments, I think. Something like...
#!/bin/sh
# r.cppmapcalc - allow C-style comments in mapcalc
if [ -n "$1" ] ; then
  # args on cmd line. Use plain r.mapcalc
  r.mapcalc $*
else
  # no cmd line args, reading input from stdin
  /usr/lib/cpp -P -undef | r.mapcalc
fi
...might work (on SunOS anyway). You need the -P on cpp to stop it producing
line numbering info.
***But...
  I am not very familiar with mapcalc. If /* or */ are valid operators
  or sequences in mapcalc, then you will have problems.
  Similarly, if a line with # in column 1 is valid, cpp will think
  you are trying to do #define, and things will go awry.
Perhaps a comment provision could be added to plans for future releases.
Indeed.
David Houlder Phone: +61 6 249 4613
Geography Department (In Aust.: (06) 249 4613)
The Australian National University Fax: +61 6 249 3770
