Thanks to David Houlder and Jill R. Schuler who suggested using C style
comments of the form /* comment */.
david@dart.anu.edu.au (David Houlder)
jschuler@ncg.scs.ag.gov
I tried a few things, and thought I would share the results,
which are not promising.
Refer to the illustration below performed using the tcsh in GRASS 4.1.
Notice that there are three errors, but only the first comment
produces the a message. If the two procedures are reversed in order,
no message whatsoever is reported from r.mapcalc.
Using the C-style comment approach produces an error message,
"you have confused me"
which probably does not hurt anything, but results in some strange
behavior.
This is unattractive since real errors are now not uniquely reported,
which makes debugging a little more challenging and confuses the user
as well as r.mapcalc use of the parser.
Conclusion: I think we cannot use /* */ WITHOUT modification to the
code to support comments.
Thanks for your comments. Any more ideas ? Onward and upward ...
steffen@longs.lance.colostate.edu
Steffen Meyer
IDS Group, Colorado State University
----- Begin Example 1 of C style /* comment */ for GRASS r.mapcalc -----
GRASS 4.1 > more test.mapcalc
/* comment */
foo = Elevation
/* a planned error */
foo2 = if
Mapset <steffen> in Location <sjbap>
GRASS 4.1 > !r.m
r.mapcalc < test.mapcalc
EXECUTING foo = ... 100%
CREATING SUPPORT FILES FOR foo
minimum value 0, maximum value 79
GRASS 4.1 >
----- End Example 1 of C style /* comment */ for GRASS r.mapcalc -----
----- Begin Example 2 of C style /* comment */ for GRASS r.mapcalc -----
GRASS 4.1 > !m
more test.mapcalc
foo2 = if()
/* comment */
foo = Elevation
GRASS 4.1 > !r
GRASS 4.1 >
----- End Example 2 of C style /* comment */ for GRASS r.mapcalc -----
