compilation error
The following is the compilation log produced for the new function that I
am writing. I'm doing this on a system in which the source code was removed
and later put back. Can anyone one clue me in here...be kind :slight_smile:
  SRC = /mqclimat/grass/src
  CMD = /mqclimat/grass/src/CMD
  HEADER = sun
  ARCH =
  GISBASE = /mqclimat/grass
  VERSION = 4.0 Summer 1991
/mqclimat/grass/src/sites/s.surf.krig
  make -f OBJ/make.rules
/mqclimat/grass/gmake4.0 -all
  HEADER = sun
  ARCH =
/mqclimat/grass/src/sites/s.surf.krig/cmd
`/mqclimat/grass/etc/bin/main/cmd/s.surf.krig' is up to date.
mqatmos{chris}20 : rm /mqclimat/grass/etc/bin/main/cmd/s.surf.krig
mqatmos{chris}21 : gmake4.0
  HEADER = sun
  ARCH =
  HEADER = sun
  ARCH =
cc -s -o /mqclimat/grass/etc/bin/main/cmd/s.surf.krig OBJ/main.o OBJ/read_sites.o /mqclimat/grass/src/libes/LIB/libgis.a -lm
ld: /mqclimat/grass/src/libes/LIB/libgis.a: warning: table of contents for archive is out of date; rerun ranlib(1)
ld: Undefined symbol
   _G_llres_format
   _G__projection_name
   _G_ascii_check
[whole long list of functions]
   _G__check_for_auto_masking
   _G_remove
*** Error code 2
make: Fatal error: Command failed for target `/mqclimat/grass/etc/bin/main/cmd/s.surf.krig'
Current working directory /mqclimat/grass/src/sites/s.surf.krig/cmd
*** Error code 1
make: Fatal error: Command failed for target `all'
cheers,
chris
