Compile help
Could anyone help a new guy compile GRASS 5b6
running linux mandrake 7
having ran ./configure then make i get the following error :-
root@localhost grass5.0beta]# make
if [ ! -d /usr/local/grass-5.0b ]; then mkdir /usr/local/grass-5.0b ; fi
if [ ! -d src/CMD/next_step ]; then mkdir src/CMD/next_step ; fi
/root/.bashrc UNIX_BIN=/usr/local/bin SRC=pwd GISBASE=/usr/local/grass-5.0b MACHINENAME=uname -n /bin/sh src/CMD/generic/CREATE_GMAKE.sh
/bin/sh: /root/.bashrc: Permission denied / ************ error ******************/
make: *** [pre-install] Error 126
[root@localhost grass5.0beta]#
Where have i gone wrong ?!
Thanks
David Armstrong
david.armstrong@dtn.ntl.com
/root/.bashrc UNIX_BIN=/usr/local/bin SRC=`pwd` GISBASE=/usr/local/grass-5.0b MACHINENAME=`uname -n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
What are the permissions on /root/.bashrc ? and does it exist?
The line in the Makefile that's giving you grief is in the pre-install:
        ${ENV} ${MAKE_GMAKE_ENV} ${MAKE_POST_ENV} ${SHELL}
It's calling the program "env" to modify the environment for
compilation, and it's trying to source your /root/.bashrc. If it doesn't
exist, just do "touch /root/.bashrc" to create an empty file.
Unfortunately, grass is still a little braindamaged in the
compilation/installation. It's generally recommended to never compile
things as root 'cause "Bad things can happen". I'd recommend giving
yourself write privledges to /usr/local. I don't know what the group
settings are for /usr/local on Mandrake, but mine are root.staff. So, by
adding myself to the group staff "adduser <username> <group>", I have
write persmission to /usr/local. Then I just "make install" as a normal
user. It'd be better if GRASS's "make" or "make all" would just compile
the binaries but not install them, then you could "su -c 'make
install'". But, for various reasons, that's currently not possible.
Hope the above helps.
| Eric G. Miller egm2@jps.net |
| GnuPG public key: http://www.jps.net/egm2/gpg.asc |
Please check Makefile, if ${ENV} was expanded to "env" properly.
It fails on a few platforms (why?).
Oh! What are the problems here? Then we can try to fix them.
We are working on this, it is a non-trivial task due to GRASS
programming history. Currently we are lucky that at least "auto-conf"
is working :slight_smile: Our plans are to restructure the GRASS sources
to small content-oriented packages (GRASS-Core, GRASS-basic, ...)
with GNU-style make/make install. I hope we manage soon but
any help would be appreciated. Please contact me on this if
you could support us.
Regards
Markus Neteler
Markus Neteler wrote:
I have It.....and I have no problem with compile......just....
set the ENV variable to this: ENV =
and line: ${ENV} ${MAKE_GMAKE_ENV} ${MAKE_POST_ENV} ${SHELL}
rewrite to: ${MAKE_GMAKE_ENV}
                ${MAKE_POST_ENV}
                ${SHELL}
Regards
Markus Neteler
        compile it and use it :slight_smile: ......
                    regards
                            Pavol Cvengros
PS: I have started rewrite of v.digit to Qt driven GUI enhanc.
Great.
BTW: Did you consider wxWindows or any other cross platform GUI?
It might have advantages in the long run.
  Bernhard
Free Software Projects and Consulting (intevation.net)
I know there has been some answers given to the issue of compiling Grass, but why not use the binary version for linux? I installed Grass 5.0 Beta 6 on Linux Mandrake 7.0, and it is running well. Is there some advantage to compiling? If not, use the binary version.
Could anyone help a new guy compile GRASS 5b6 running linux mandrake 7 having ran ./configure then make i get the following error :-root@localhost grass5.0beta]# make
Michael Pool, RPA
Anthropology/Geography Department
Austin Community College
mpool@austin.cc.tx.us
    the binary version.
Well a bunch of possible reasons come to mind:
* Hacking around the source code of GRASS
* Using updated development versions from CVS.
* Nonstandard Configuration of the system
  Bernhard
