Hello!
I have a problem compiling GRASS for the "OpenWindows" environment (Sun). After
hours of compilation the process terminated with this error message:
cc -O -I/usr/openwin/include -D_NO_PROTO -I/usr/local/grass/grass4.1/s
rc/m apdev/Vlib -I/usr/local/grass/grass4.1/src/mapdev/diglib -I/usr/loc
al/g rass/grass4.1/src/include -c abwcolr.c
/usr/local/grass/grass4.1/src/include/std_incs.h: 39: Can't find includ
e fi le Xm/Xm.h
/usr/local/grass/grass4.1/src/include/std_incs.h: 40: Can't find includ
e fi le Xm/ArrowB.h
/usr/local/grass/grass4.1/src/include/std_incs.h: 41: Can't find includ
e fi le Xm/ArrowBG.h
/usr/local/grass/grass4.1/src/include/std_incs.h: 42: Can't find includ
e fi le Xm/BulletinB.h
*** Error code 2
make: Fatal error: Command failed for target `OBJ.sun4/abwcolr.o'
Current working directory /usr/local/grass/grass4.1/src/xgrass/libes/Xg
d
*** Error code 1
make: Fatal error: Command failed for target `all'
GISGEN failure at STEP: src/xgrass/libes
It can apparently not find some Motif-includes. Since I chose the "no-Motif" op
tion when I ran "/utils/setup", I thought that "Motif-includes" should not be n
ecessary. Can someone tell me if they still are, and where I should specify whe
re they can be found in the $ARCH - script.
Another question;
To get the X user interface for my GRASS installation,I understood from the Ins
tall-Guide that I had to copy the content of "CMD/lists/GRASS.X" into "CMD/list
s/local". Am I right?
Thank you in advance!
Trond Rinde
PS! Thanks for all the answers to my previous questions. They have been extreme
ly helpful.
