Compile problem from a beginner.
Hi, When I try to run GISGEN.head,
There is following error message:
first step: #man
GISGEN failure: #man - not found in lists/GRASS lists/local
Would some people tell me why?
Thanks very much
Peizhong Wu
University of Michigan
Ann Arbor, MI 48105
Everything you want to compile under the standard GRASS distribution
that's contained in the lists/GRASS lists/local file must be
un-commented, i.e., delete the '#' symbol. The programs in the contrib/
garden/, etc. directories must be complied separately using the gmake4.1
command in each of those directories, but ONLY after successful
compilation of the the core GRASS programs.
Also, the programm v.support has a bug; so be sure to get the updated
code for build.vector.c. For details on this, look at the FAQs for
GRASS.
Cheers!
Tom Adams
first step: #man
Thanks very much
Peizhong Wu
Ann Arbor, MI 48105
Tom Adams adams@ohrfc.noaa.gov
Development & Operations Hydrologist NWS-Ohio River Forecast Center
1901 S. State Route 134 Wilmington, OH 45177
(513) 383-0527 (VOICE) (513) 383-0033 (FAX)
