Compile problem
Hi, When I try to run GISGEN.head,
There is following error message:
/yin5/wupz/grass/src/display/d.3d
  make -f OBJ/make.rules
cc -s -o /yin5/wupz/grass/etc/bin/main/inter/d.3d OBJ/main.o OBJ/threed.o
OBJ/transform.o OBJ/clip.o OBJ/get_range.o OBJ/check_opt.o
OBJ/get_inputs.o OBJ/sigint.o OBJ/get_row.o OBJ/draw_face.o
/yin5/wupz/grass/src/libes/LIB/libD.a
/yin5/wupz/grass/src/libes/LIB/libdisplay.a
/yin5/wupz/grass/src/libes/LIB/libraster.a
/yin5/wupz/grass/src/libes/LIB/libgis.a
/yin5/wupz/grass/src/libes/LIB/libvask.a -lcurses -ltermlib -lm
ld: fatal: symbol `Def_term' is multiply defined:
        (file /usr/ucblib/libcurses.a(curses.o) and file
/usr/ccs/lib/libtermlib.a(setupterm.o));
ld: warning: symbol `ttytype' has differing sizes:
        (file /usr/ucblib/libcurses.a(curses.o) value=0x32; file
/usr/ccs/lib/libtermlib.a(setupterm.o) value=0x400);
        /usr/ccs/lib/libtermlib.a(setupterm.o) definition taken
ld: fatal: File processing errors. No output written to
*** Error code 1
make: Fatal error: Command failed for target
`/yin5/wupz/grass/etc/bin/main/inter/d.3d'
GISGEN failure at STEP: src/display/d.3d
Would some people tell me why?
Thanks very much
Peizhong Wu
University of Michigan
Ann Arbor, MI 48105
Try removing /usr/ucblib from your LD_LIBRARY_PATH. It caused me a lot of
grief at one time!
  -Malcolm Williamson
On Mon, 24 Mar 1997,
*** Error code 1
Thanks very much
Peizhong Wu
Ann Arbor, MI 48105
