Compiling 4.1
  I've taken the plunge and have started to
install GRASS4.1 on our Sun Sparc 2 with OpenWindows2.0.
Compilation stops with src.alpha/display/d.labels. Here is
the GISGEN output:
GISGEN: src.alpha/display/d.labels - Fri Jun 18 17:56:40 CDT 1993
/usr/local/grass4.1/src.alpha/display/d.labels
  mkdir OBJ
  make -f OBJ/make.rules
rm -f OBJ/main.o
cc -O -I/usr/local/grass4.1/src/include -c main.c
mv main.o OBJ/main.o
rm -f OBJ/get_loc.o
cc -O -I/usr/local/grass4.1/src/include -c get_loc.c
mv get_loc.o OBJ/get_loc.o
rm -f OBJ/opencell.o
cc -O -I/usr/local/grass4.1/src/include -c opencell.c
mv opencell.o OBJ/opencell.o
rm -f OBJ/display.o
cc -O -I/usr/local/grass4.1/src/include -c display.c
mv display.o OBJ/display.o
rm -f OBJ/in_window.o
cc -O -I/usr/local/grass4.1/src/include -c in_window.c
mv in_window.o OBJ/in_window.o
rm -f OBJ/check_resp.o
cc -O -I/usr/local/grass4.1/src/include -c check_resp.c
mv check_resp.o OBJ/check_resp.o
rm -f OBJ/show.o
cc -O -I/usr/local/grass4.1/src/include -c show.c
mv show.o OBJ/show.o
rm -f OBJ/where.o
cc -O -I/usr/local/grass4.1/src/include -c where.c
"where.c", line 75: warning: statement not reached
mv where.o OBJ/where.o
rm -f OBJ/modify.o
cc -O -I/usr/local/grass4.1/src/include -c modify.c
  Any suggestions on where to start looking for
the problem?
  Thanks for any advice.
Sharyl Walker
Dept. of Agricultural Engineering
University of Illinois
guernsey@holstein.age.uiuc.edu
In info.grass.user you write:
the GISGEN output:
rm -f OBJ/where.o
rm -f OBJ/modify.o
the problem?
Did you solve your problem? It seems from the output that you did not have an
error. It should not have died from a warning. I would not worry about the
warning message if the binaries are working alright.
- Jim
[Jim] pirzyk@uiuc.edu ------------------------------------------
TAC & GrassNet System Administrator, US Army Corps of Engineers
Construction Engineering Research Labs, Champaign IL USA
