I'm very new to C progamming, thus, very new to GRASS programming.
Can anyone tell me what the following error message means when I try to run gmake4.0.
make: Fatal error in reader: OBJ.sun4/make.rules, line 99: Unexpected end of line seen.
Many thanks in advance. If you need to see any of the code or Gmakefile I will post them.
Thank you.
Christine Weiss
Hunter College
Dept. Geology & Geography
Christine Weiss (cmw@nycparks.gov) writes on 12 May 93:
sounds like you may have an error in your Gmakefile. Check to make
sure that no tabs are missing and that your rules are well formed.
if you still can't figure it out, trying sending me either a
uuencoded version your Gmakefile or the output of 'od -c Gmakefile'
(since tabs may sometimes get destroyed in the mail).
--Darrell
In article <9305121258.AA21568@nycparks.gov> you write:
Thank you.
Christine Weiss
Hunter College
what's grass?
are you sure that everything which is supposed to be a tab rather than a space
is? have you any unclosed " or '?
Eric
_ "just a Texan a long way from home"
_| ~-. Eric Barber, BNR Europe Limited, London Road, Harlow, England CM17 9NA
\, *_} AT&T/BT/etc. +44 279 403527/429531 x 3527, ESN (NT/BNR) 6 742 3527
\( DISCLAIMER: Working at, not speaking for, BNR | Eric.Barber@bnr.co.uk
