Compiling Grass 5.0
Hi Michel, hi all,
thank you for your remarks. I have updated the source package of GRASS 5.0
today. It is available at Hannover site, and will be uploaded soon to
Baylor and the mirrors.
GISGEN fails in src/mapdev/v.digspline because an error in
src/mapdev/v.digspline/Gmakefile, line 224 :
        if [ ! -d $(TXT)/DIGIT ]; mkdir $(TXT)/DIGIT; fi
should be
        if [ ! -d $(TXT)/DIGIT ]; then mkdir $(TXT)/DIGIT; fi
same error line 231 ("then" is missing)
This error is fixed now.
the directory "CVS" in src/mapdev/v.digspline/digitizers must also
be suppressed if you don't want COMPILE to stop here...
Also fixed.
INSTALL doc doesn't remind you to go to src/display/devices/XDRIVER
and run /..../grass5.0beta/src/CMD/gmake5.0 (absolute path mandatory)
XDRIVER and CELL driver are new in the list of modules, which shall
be compiled. It is done by the script "COMPILE.sh" now.
Module specific bugs (due to floating point changes or whatever) please
send to
   grass@baylor.edu
We collect and fix it for the "GRASS 5.0 stable" version for spring.
Thank you for the overwhelming response (especially downloads).
With your help we and us can develope GRASS for your needs. GRASS
is open source - your chance to improve this GIS!
"Happy downloading..."
    Markus Neteler
