compiling grass5.0beta7 on linux
On Mon, Apr 24, 2000 at 02:16:31PM +0200, Andreas Lange wrote:
Hi!
just in case someone else wants to compile the new source code
(grass5.0beta7.tar.gz):
There is an error in r.cost (src/raster/r.cost) which stops compiling of
this module: INFINITY undeclared in function main.
Hi there,
INFINITY is defined in
/usr/include/math.h: INFINITY representation of the infinity value of type 'float'
If r.cost is not compiling on your machine, I assume your compiler
is not installed properly. The declarations in src/raster/r.cost seems
to be o.k.
Kind regards
Markus Neteler
Markus Neteler wrote:
Hi there,
to be o.k.
Kind regards
Markus Neteler
Hi Markus,
sorry to insist on that, but on my Red Hat Linux 5.2, glibc 2.0.7,
INFINITY is not defined in /usr/include/math.h or elswhere.
On IRIX 6.2 INFINITY is not defined too and compilation of r.cost stops
too.
Please do not assume that all Unix systems are the same or compatible
with some standards Linux or glibc introduced a very short time ago. I
still hope that GRASS will continue support for other Unix platforms
than Linux.
A portable program should use HUGE_VAL for a undefined infinite which is
defined in <math.h> and in <limits.h>. HUGE_VAL should be compatible
with systems that use IEEE floating point format. Another way is the
function isinf(double X), but this is BSD and is not portable to systems
that strictly confine to SYSV.
I don't know if the code in main.c is correct as INFINITY is defined as
a float but null_cost is a double variable. Other possible defines:
FLT_MAX and DBL_MAX from <limits.h> contain the biggest value a float
resp. a double variable can hold. One could use FLT_MAX instead of
INFINITY.
Please contact me if you whish me to investigate this further. I can
provide a patch.
cu
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de, A.C.Lange@GMX.net
