Compiling MAPGEN under Linux.
Date: Tue, 31 May 1994 11:16:22 -0700 (PDT)
To: grassu-list@max.cecer.army.mil
Subject: Compiling MAPGEN under Linux.
Has anyone successfully compiled MAPGEN under Linux yet? I have had some
limited success but I'm not all the way there yet. Some background:
I started with Changyong Cao's XIS collection of Linux, X-Windows, and
GRASS 4.1. The installation went fine and the core routines of GRASS work
as expected (remarkably fast too even compared to our Sparcstation 2!).
We use MAPGEN a lot in our line of work so compiling that was my next
mission. I started with version 4.0 which is what we use on the Sun with
GRASS 4.1 (since MAPGEN 4.1 had problems). I was able to compile most of
the source code but ran into problems while running "make.mapdef".
Since we want the latest version of MAPGEN my next step was to try and
compile that. I pulled version 4.11 off of the moon ftp site and tried
compiling both on our Sun and on our Linux box. The Sun compile went well
until I got to PROJ.4. Need for an ANSI C compiler stopped me short there
and I should get my GNU compiler this week to finish that install. I then
tried to compile under Linux and got through most of the code until I got
to PROJ.4.
PROJ.4.3.1 on charon.er.usgs.gov (128.128.40.24) uses "configure"
followed by "sh intall." That may be a little more forgiving for
Linux. Obviously, with gcc on Linux, ANSI C problems go away.
You may want to use "--prefix=" with configure---check README
for reasons.
PROJ.4 does not have a Gmakefile but there is an "install" routine that
apparently works for several machine architectures (Sun, DG, etc.) but
not for Linux. Thus, even though I do have an ANSI C compiler, I do not
have the proper "install" code to complete the installation.
I am sure that Gmakefile is a fine system, but I try to stay away
from things like this. I have spent too many hours cursing the X11
make system to want to get involved with another. IMHO, the
"configure" system, from FSF (GNU), is a good system. Not perfect,
but it handles most of the problems I have seen and does so
with normally available software. I intend to stick with it.
Has anyone figured this out yet?
(Some postscripts---Apparently the topquark ftp site does not have Linux
binaries for MAPGEN. I have yet to check the SCS ftp site since I do not
have their address but I am assuming that they are not dabbling in Linux.)
Brad Stewart
stewartb@cpva.saic.com
Related to the Linux problems, if I can figure out how to use a Sony
CDU-6211 drive with Linux, the primary development system for PROJ.4
and MAPGEN (my base distribution) will be Linux. But I have run into
a snag here. I'm going to be pissed if I have to by another drive!
Another point, if I can get Linux up and going on Pluto I may be
willing to make a Linux binary distribution available on charon
(mirrored on moon). But this will require using environment
variables rather than compiled-in settings to point to required
library directory. Any comments on this are welcome.
MAPGEN poses additional problems, because I am not sure what
value-added work has been made to moon distribution (principly by SCS
folks). Thus I do not know if my version is useful to GRASS users in
general. Again, comments welcome.
Gerald (Jerry) I. Evenden Internet: gie@charon.er.usgs.gov
voice: (508)563-6766 Postal: P.O. Box 1027
  fax: (508)457-2310 N.Falmouth, MA 02556-1027
