Hi everybody
After compiling grass5.0beta3 on SuSE 6.0 and Linux 2.2.9, I tried to compile
NVIZ2.2.
It stopped with the following error:
In file included from togl.h:19,
from tkAppInit.c:8:
tkInt.h:800: parse error before `Tcl_Obj'
tkAppInit.c: In function `Tcl_AppInit':
tkAppInit.c:73: `Tk_SafeInit' undeclared (first use in this function)tkAppInit.c:73: (Each undeclared identifier is reported only once
tkAppInit.c:73: for each function it appears in.)
make[1]: *** [OBJ.i686-linux-elf/tkAppInit.o] Error 1
make[1]: Leaving directory `/usr/src/grass5.0beta/src.contrib/GMSL/NVIZ2.2/src'
make: *** [nvwish] Error 2
It doesn't make sense to me, but because there is something with Tcl/tk in the
Error Message, I installed a newer version of Tcl/Tk. I had version 8.04 and
now I have 8.05 but compiling is still not working.
Kurt Gerber
Hello Kurt !
I had the same problem when compiling Nviz on Suse. "Tk_SafeInit" is
declared in tk8.0.h, but after installing the tcl/tk-Stuff with Suse, you
still have "old" tk.h and tcl.h (version 7.x). I symlinked the "new"
tk8.0.h to tk.h and backuped the "old" tk.h !
This worked for me! Perhaps it can help to fix your probelm !
Cheers, Michael
Michael Schulz
Christoph-Mang-Str.5 Geologisches Institut
79100 Freiburg Universitaet Freiburg
Albertstr. 23b
79104 Freiburg
On Thu, 30 Sep 1999, Kurt Gerber wrote:
Hi everybody
NVIZ2.2.
from tkAppInit.c:8:
Kurt Gerber
Hi
I tried with your suggestion. I symlinked tk8.0.h with tk.h. But it didn't
work.
I've got the following error message:
5.0beta/src/include -c tkAppInit.c
In file included from tkAppInit.c:7:
/usr/X11R6/include/tk.h:1275: parse error before `Tcl_Obj'
/usr/X11R6/include/tk.h:1468: parse error before `Tcl_Obj'
/usr/X11R6/include/tk.h:1495: parse error before `Tcl_Obj'
/usr/X11R6/include/tk.h:1542: parse error before `Tcl_Obj'
/usr/X11R6/include/tk.h:1551: parse error before `Tcl_Obj'
from tkAppInit.c:8:
Cheers, Kurt
On Fri, 01 Oct 1999, Michael Schulz wrote:
Hello Kurt !
Cheers, Michael
Michael Schulz
Albertstr. 23b
79104 Freiburg
Hi everybody
NVIZ2.2.
from tkAppInit.c:8:
Kurt Gerber
Hi Kurt !
Right now i am not at the computer where i installed nviz. But you are
right: i forgot to say, that i added (now i am not sure, where) a
include<tk.h> somewhere. I suppose it was in tkAppInit.c (not sure).
I will write you again when i have looked it up at work.
Cheers, Michael
Michael Schulz
Albertstr. 23b
79104 Freiburg
On Fri, 1 Oct 1999, Kurt Gerber wrote:
Hi
work.
from tkAppInit.c:8:
Cheers, Kurt
>Hello Kurt !
>Cheers, Michael
>Michael Schulz
> Albertstr. 23b
> 79104 Freiburg
>> Hi everybody
>> NVIZ2.2.
>> from tkAppInit.c:8:
>> Kurt Gerber
Hi Michael
The Problem is solved! I compiled Nviz2.2 successfully. The Problem was: I
symlinked only tk.h, but of course I had to do the same thing with tcl.h.
Thanks for your help!
Kurt
On Sat, 02 Oct 1999, you wrote:
Hi Kurt !
Cheers, Michael
Michael Schulz
Albertstr. 23b
79104 Freiburg
Hi
work.
from tkAppInit.c:8:
Cheers, Kurt
>Hello Kurt !
>Cheers, Michael
>Michael Schulz
> Albertstr. 23b
> 79104 Freiburg
>> Hi everybody
>> NVIZ2.2.
>> from tkAppInit.c:8:
>> Kurt Gerber
