Many thanks for your answer, but my problem isn't solved yet.
Nalneesh Gaur wrote: "All you had to do was to type r.water.fea and things
would have kicked off from there"
But when I type r.water.fea, the only answer I get is "Not found". Because
the file r.water.fea is not created in $GISBASE/bin after compilation. My
question is why the only file created after compilation is in $GISBASE/etc.
Xavier Ros
Dept. de Geologia
U. Geodinamica Externa i Hidrogeologia
Universitat Autonoma Barcelona
Maybe!!!!!!!!!!!!!!!!
I did not follow the discussion about this but did you runned the linkage
module in Grass: MAKELINKS.sh. This links all your programs
from the $GISBASE/etc/bin to $GISBASE/bin. You need to do this after each
recompile or compilation modification.
Bart
| ir. Bart Cosyn |
| ERS1/2 project |
| Laboratory for Hydrology and Water Management |
| University of Gent |
| Coupure 653, B-9000 Gent |
| Belgium |
| Tel: +/32/9/2646137 |
| Fax: +/32/9/2646236 |
| E-mail: bcosyn@allserv.rug.ac.be |
