Compliling r.water.fea
r?29??93?12?28?58?pm@bnr.ca>
content-type: text/plain; charset=US-ASCII
organization: University of Illinois at Urbana
mime-version: 1.0
reply-to: grassu-list@max.cecer.army.mil
newsgroups: info.grass.user
originator: daemon@ux1.cso.uiuc.edu
Nalneesh,
Many thanks for your answer, but my problem isn't solved yet.
Nalneesh Gaur wrote: "All you had to do was to type r.water.fea and things
would have kicked off from there"
But when I type r.water.fea, the only answer I get is "Not found". Because
the file r.water.fea is not created in $GISBASE/bin after compilation. My
question is why the only file created after compilation is in $GISBASE/etc.
                                       Xavier Ros
                                Dept. de Geologia
                                U. Geodinamica Externa i Hidrogeologia
                              Universitat Autonoma Barcelona
        You have to run the MAKELINKS script in src/CMD to create
        a link from bin to etc/bin/...
Regards
        Andreas Holz
