At 10:21 PM 11/5/96 GMT, you wrote:
hi
i have recently instaled Grass on my Linux Box, and i would like
to make a composite picture
I have the 3 files (spot.1 spot.2 spot.3) for the RGB channel
The probleme is when i run i.composite
i don t know how to place the files in the directory
wich directory shall i make , and where to put those 3 filesThanks
Marc.
Grunberg MarcDEA Photonique et Image
Universite Louis Pasteur Strasbourg
grunberg@doc.u-strasbg.fr
http://saphir.list.jussieu.fr/~marco
IRC: nick Marco
Are the SPOT images already rectified and in a .BIL format? If so, you would
first need to create a GRASS mapset and location in the map projection and
coordinate system that matches the SPOT images.
If the images are not rectified, create a GRASS mapset and location with no
map projection (x,y).
Then run i.tape.other to convert each band to a GRASS format. Next, run
i.group to define an imagery group and include all the files in that group.
Finally, run i.composite to create a composite image.
Jim Schmidt
avenues@sonnet.com
