configure error
When I try to compile grass5.0beta3 on
a SuSe 6.2 box, all I get is:
silvestre:/usr/local/grass5.0beta # ./configure
loading cache ./config.cache
checking host system type... i686-linux-elf
checking for gcc... gcc
./configure: line 625: syntax error near unexpected token `"(c'
./configure: line 625: ` echo $ac_n "(cached) $ac_c" 1>&6'
Is this a problem of the configuration program?
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
As far as I can tell this problem was only present in
the distribution from www.geog.uni-hannover.de. I have
downloaded the file grass5.0beta3g.tar from
www.baylor.edu and there is no problem.
(BTW: it's odd that the beta3 be on a directory
named grass5.0beta2)
Agus
Dr. Agustin Lobo
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
Agus
Dr. Agustin Lobo
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
