Connecting UNIX & DOS PC's
Greetings from Idaho !
We are trying to find a cost-effective (CHEAP) way of connecting our
AT&T 386 UNIX GRASS machine and our ATT&T 6386E DOS ARC/INFO machines
together for ease in file transfer. Diskettes are fine until the
compressed file size exceeds diskette size. PCI seems too slow and
I am unsure of what's out there like the old LAP-LINK I used to use.
Does anyone hvae any inexpensive solutions?
Thanks in advance -
David Hoover
Manager, CGIS Section
Technical Services Staff
USDA-SCS Idaho State Office
a16dhoover@attmail.com
208 334 1525
You may be better off biting the bullet and buying some of the now
relatively inexpensive ethernet cards, since serial line solutions will
entail either putting many serial ports into the Unix PC or walking back and
forth with one end of the serial cable plugging into various DOS PC's.
Joshua Lieberman, Ph.D. josh@turb01.dmc.com
ENSR Consulting and Engineering wasser@world.std.com
35 Nagog Park, Acton, MA 01720 508-635-9500
