continued heartburn over r.in.tiff
  Having read your E mail I went in and did the same thing that
was said. ie convert to a sunrast format using xv and then doing a
r.in.sunrast. The conversion was fine but when I got the image onto
the monitor all I get was a blank screen. I then tried to run the
r.in.tiff and it said that the command was not found.
  My research is mainly to convert a collection os tiff and giff
files and bring it up on grass. Please help my with the following.
a) Where do I get the r.in.tiff command file
b) Do you guys know of any utility program that can convert from
   giff and tiff files to the grass formats.
Please do not ignore this E Mail. Since we are working on a similar
problem let us try to help each other.
Thanks
If that's true, then perhaps you have omitted setting the region to the
appropriate map and erasing the monitor. R.in.sunrast failed with us too,
but at least we got to see something - a messed up map.
As I said, the r.in.tiff code should be packed somewhere in your GRASS
source, under /src.contrib/SCS/r.tiff. You have to compile this code
before you can use it.
that can convert from > giff and tiff files to the grass formats.
Again, XV can read both GIF and TIFF. The problem therefore lies with the
GRASS-import commands. Compile r.in.tiff and your troubles are over...
are working on a similar > problem let us try to help each other.
Thanks
P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam martijn@scanner.frw.uva.nl
