Hello,
I have made some progress in converting SDTS point data file into GRASS.
However, there are number of problems that I am struggling with and I
would very much appreciate some help from those that are familiar with
SDTS conversion.
The SDTS data file that I would like to import has the following
metadata.
Planar:
Map_Projection:
Map_Projection_Name: Albers Conical Equal Area
Alber_Conical_Equal_Area:
Standard_Parallel: 29.5
Standard_Parallel: 45.5
Longitude_of_Central_Meridan: -96
Latitude_of_Projection_Origin: 23
False_Easting: 0.0
False_Northing: 0.0
When I followed the menu options for creating a new location, I got the
following error: (I used the "Other" option then selected Albers Conical
Equal Area Prjection)
Processing CATD module
Processing STAT module
Processing IDEN module
Processing XREF module
Warning: Current GRASS projection (Other) does not match SDTS data set
projection (Latitude-Longitude)
Entering 'Information Only' mode
Processing IREF module
INFORMATION ABOUT THE SDTS DATA SET
Identification module: PREFIDEN.DDF
Standard identification: SPATIAL DATA TRANSFER STANDARD
Standard version: 1992 AUGUST 28
Standard documentation reference: FIPS PUB 173 - 1992
Profile identification: SDTS TOPOLOGICAL VECTOR PROFILE
Profile version: VERSION 1.0 JUNE 10, 1994
Profile documentation reference: FIPS 173-1 PART 4
Title: BOX_COV,LANDFILL:
Data ID:
Data structure: ARC/INFO
Map date:
Data set creation date: 19961122
Scale:
Comment:
External Spatial Reference module: PREFXREF.DDF
Reference System name: GEO
Horizontal Datum: NONE
Zone Number: 0
Spatial Domain module: PREFSPDM.DDF
Spatial Domain type: MINMAX
MAP: box_cov
THEME: *
MANIFOLD: box_cov
BOUNDARY:
MIN_X MIN_Y MAX_X MAX_Y
-124.106422 25.935798 -66.993011 48.986392
Done.
According to the error message, it looks like I should have selected
Long-Lat map projection instead of "Albers Conical Equal ARea". So, I
creasted a new location with Long-Lat projection and proceeded to
convert the data. Unfortunately, v.in.sdts exited with segmentation
fault.
Processing manifold: box_cov
Processing LE module: PREFLE01.DDF
Processing PC module: PREFPC01.DDF WARNING: No area_point for attributed
area 'PC01#2' found
Processing NO Module: PREFNO01.DDF
Processing NE Module: PREFNE01.DDF . . . . . . . . . . . . . . . . . . .
Processing GRASS dig_atts
Schema Type = '1'
Processing attribute modules . . .
Writing Composite Attribute modules
Writing Attribute Primary modules (6)
PREFAXRF.DDF
PREFAPNE.DDF Segmentation fault (core dumped)
Well, I am stucked! I would appreciate any help resolving this problem.
Thank you for reading this long post.
Henry Shin
