I really appreciate knowing that both Scott Miller and Bill Baker (and
probably many other persons, I assume) have used the DISPLAY command in
ARC/INFO to output to a ASCII .txt file with no problem. When I was
converting files from ARC/INFO to GRASS, I was getting a BAD WRITE error. I
was planning to call the ARC people, but I got around the problem by using
the REPORT command.
Just to check the procedure again, I just used the DISPLAY command on one of
my files. The following is the error that I get if I use the DISPLAY command
in INFO to create the ASCII .txt file for GRASS.
AN EXAMPLE OF THE ERROR:
Arc: INFO
INFO EXCHANGE CALL
26/01/1995 11:30:42
INFO 9.42 11/11/86 52.74.63*
Copyright (C) 1994 Doric Computer Systems International Ltd.
All rights reserved.
Proprietary to Doric Computer Systems International Ltd.
US Govt Agencies see usage restrictions in Help files (Help Restrictions)
ENTER USER NAME>ARC
ENTER COMMAND >SEL VEGCL.PAT
7 RECORD(S) SELECTED
ENTER COMMAND >LIST
$RECNO AREA PERIMETER VEGCL# VEGCL-ID
1 -40.320 29.934 1 0
2 25.797 59.846 2 64
3 2.175 9.229 3 63
4 4.871 14.019 4 67
5 2.587 16.535 5 65
6 3.039 11.302 6 66
7 1.852 7.729 7 68
ENTER COMMAND >OUTPUT /home/sayeed/vegcl.txt
ENTER COMMAND >ITEMS
DATAFILE NAME: VEGCL.PAT 01/26/1995
4 ITEMS: STARTING IN POSITION 1
COL ITEM NAME WDTH OPUT TYP N.DEC ALTERNATE NAME
1 AREA 4 12 F 3
5 PERIMETER 4 12 F 3
9 VEGCL# 4 5 B -
13 VEGCL-ID 4 5 B -
ENTER COMMAND >DISPLAY $RECNO, AREA, PERIMETER PRINT
LU 8 BAD WRITE (DBWRIT)
ENTER COMMAND >OUTPUT arcsnp
ENTER COMMAND >Q STOP
Arc:
EXAMPLE ENDS.
I do have enough space and write permission in my /home/sayeed directory. I
talked to the system administrator, but he was clueless. I have been using
ARC/INFO 7.0.2 and UNIX system on IBM RS/6000. Has anyone else got the same
type of problem? If anybody has any clue, please let me know.
Thanks in advance.
- Sayeed
sayeed@blue.weeg.uiowa.edu
sayeed@weirich530.geography.uiowa.edu
