Converting Arc 7.0.2 to Grass
> I have been trying to convert Arc/Info 7.0.2 vector files into GRASS raster files.
> My previous attempts have yielded grass vector files, but I could not generate proper
> topology even after using v.support. It seems that the v.in.arc is properly converting
> the lines, but missing the attribute values. I would greatly appreciate if you could
> send me the detailed procedure for conversion of Arc files into grass vector files.
Rick Thompson- Research Specialist E-mail: rick@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-8498
Ozark Hall Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
Hi there Rick ,
My name is Jeremy Dunn. I was interested in your success rearding ArcInfo to
Grass (vector or raster) .Did you ever get hold of a step by step guide ?
I would be interested to get a copy og it if you did.
Thanks
Jeremy.
P.S. I'm basically trying to get some Mississippi Basin flood Maps into Grass.
Thanks
Jeremy
