Converting Arc 7.0.2 to Grass
I am not able to get v.in.arc to recognize more than one column in
the .txt file -- I can't understand what's wrong since it looks fine to
a text editor.
Has anyone successfully done this conversion and managed to keep attribute
values intact?
Neel Smith
smith@hcacad.holycross.edu
Neel,
I'm not sure that I understand your question properly. I believe that v.in.arc
only allows you to select one column for the actual attribute; if you want
multiple attributes, you'll have to import the coverage into multiple GRASS
vector layers, specifying different attribute columns each time.
Support your local OGIS!! :slight_smile:
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
