Converting ascii data to GRASS4.1 format - continued
  With help from several of you, I was able to convert
ascii x,y data which defined the boundary of an area to a GRASS
map using v.import. Now the question is: is there a way to
read in a category number along with the x,y coordinates defining
the boundary or must one go through v.digit or manually create
a dig_att file to label the bounded areas?
  Thanks again for any advice.
Sharyl Walker
Department of Agricultural Engineering
University of Illinois
guernsey@holstein.age.uiuc.edu
