Converting HUC files
I'm having trouble converting the SDTS files to GRASS format for the USGS 250K
Hydrologic Unit map of the Coterminus US. The 2M scale map worked just fine,
but the 250K map gives the following error:
FLAG: Set the following flag?
    Information only mode?(y/n) [n] y
    object link table only; no attribute tables?(y/n) [n]
Processing CATD module
Processing STAT module
Error: Could not read FIPS 123 Data Subfield for PREFSTAT.DDF.
Unable to process SDTS STAT module.
ERROR: Unable to process SDTS CATS file. Exiting
Does anyone have any suggestions?
Thanks for any time you can give to this problem.
Michael Hanratty Phone: (612) 627-4590
Dept. of Civil Engineering (612) 626-0024
University of Minnesota Fax: (612) 627-4609
St. Anthony Falls Laboratory
Mississippi River at 3rd Ave SE
Minneapolis, MN 55414
