is there a way to fill polygons with their corresponding attribute? I have a map with soil properties in E00-format, which I imported into grass. The map is displayed and d.what.vect correctly displays one attribute of the polygon.
Now I would like to create a rastermap containing datapoints with the attribute of the surrounding polygon, that is I want to fill each polygon with its attribute-value. I checked the grass-commands, but I could not find any command that does this. v.to.rast returns only the edges of the polygon with an empty interior. I cannot interpolate with r.surf.* because the attribute-values are not related to each other like for example elevation-values. Instead i need the exact attribute-value.
Is there a way to do this? In principle it seems possible because d.what.vect also “knows” the correct value, no matter what point inside a polygon I click.
The second question concerns the ONE attribute displayed. The E00-file contains about 20 attributes for each polygon. Can I
- view these values and can I
- use them for filling polygons and creating a rastermap?
TIA, Stefan
Hi Stefan,
1. Run v.digit on your vector file
2. Use "t - Re-type a line (AREA/LINE)" from within "Edit" menu
3. Change all your polygons into area using the tool mentioned above
4. Use "Label" command and label your areas
5. Run v.to.rast. Your raster areas will have discrete values, the same
you gave them by "Label" command in v.digit
It is critical to use "t - Re-type a line (AREA/LINE)" within v.digit and
convert polygons into areas. They should appear in grey color in v.digit.
Rado
Rado Bonk
Geography and Geology
UNO, Nebraska, 68182-0199,
rado@cosmos.unomaha.edu
On Mon, 9 Oct 2000 Stefan.Neumann@agrar.uni-giessen.de wrote:
Is there a way to do this? In principle it seems possible because d.what.vect also "knows" the correct value, no matter what point inside a polygon I click.
TIA, Stefan
Stefan.Neumann@agrar.uni-giessen.de a écrit :
You should run v.support on the vector file generated (m.in.e00 extract the polygon
information, but does not run v.support). Area are basicaly numbered as they were in
the e00 archive. All other attributes are stored in the dig_cat directory, that should
contain as many category files than the number of polygon's attributes. You can use
them to do a "reclass" on the raster file generated by v.to.rast (cat file are named
<dig filename>.<attribute name>).
If you have no areas after v.support, it means that either your arc/info input file
defines only lines and not polygons, either there is some hiden bug in m.in.e00. You
can run m.in.e00 with the option "verbose=5 logfile=xxx" and send me the xxx file, so
I could figure out where things are going wrong.
Michel WURTZ - DIG - Maison de la télédétection
500, rue J.F. Breton
34093 MONTPELLIER Cedex 5
