Marco posted:
I have to import a tiff map in to a raster map with latitude/longitude
projection (with use of r.in.tiff && r.rectify).
For this tiff map i have the coordinate of the upper left vertex
in the `GAUSS BOAGA timezone 1 system' and i need to convert these in
latitude/longitude.
The questions are:
- What does `GAUSS BOAGA timezone 1 system' mean ?
It' s an old Italian modified UTM projection which uses it's own
coordinate system and Rome 1950 Datum.
- How can i convert these in latitude/longitude ?
I suppose that the easiest way is to get a map of the zone with both
Gauss-Boaga and geographic coordinates (there are several).
- Where can i get some docs about this ?
Any Italian cartography text should be usefoul.
Hope this helps.
Ciao.
Massimo Vincini- agronomist
funzionario tecnico Facolta di Agraria
Universita Cattolica del Sacro Cuore - Piacenza
phone: +39(0)523-599155 fax:39(0)523-599358
E-mail: radlab1@pc.unicatt.it
