Hi!
I'm tring to compile and after ./configure I get this:
/root/.bashrc UNIX_BIN=/usr/local/bin SCR=/usr/local/grass5.0beta
GISBASE=/usr/local/grass5.0beta MACHINENAME=grass.lv.parnu.ee /bin/bash
scr/CMD/generic/CREATE_GMAKE.sh
/bin/bash: /root/.bashrc: Permission denied
make: *** [pre-install] Error 126
What's up?
Hanno
-----Original Message-----
Sent: Tuesday, September 07, 1999 12:04 PM
To: grass@cecer.army.mil
Subject: Re: Box Counting MethodI did something similar to study the sprectral response of
a high reolution sensor for each cell of a coarse resolution
sensor.I just made an script (I think that I actually contributed to Markus N.)
that produces a numbered image, i.e., like r.clump but each pixel has
an individual integer value.You could run a similar process for each given resolution and create a
suite of rasters (numbered.1, numbered.2, numbered.3 ...) that would
match as:numbered.1:
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
19 20 21 22 23 24 25 26 27
....numbered.2
1 1 2 2 3 3 4 4 5 5
1 1 2 2 3 3 4 4 5 5
6 6 7 7 8 8 9 9 10 10
....Then you select the resolution of your fracture maps
(0: no fracture; 1: fracture; if you have different types
of fractures, just add more categories) and use
r.stats with each numbered.x map and your fracture map,
to obtain, for each numbered.x, a file with 2 columns:numbered.1 fracture
1 0
2 0
3 1
4 1
5 6etc.
Export to your stats program and count the number of "1"
for each numbered.x. From this series you can calculate
the fractal dimension.It might seem complicated, but it's not.
Agus
****NOTE NEW PHONE NUMBER*****
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/aloboOn Mon, 6 Sep 1999, Michael Schulz wrote:
> Dear List!
> Together with a diploma student, we are trying to use GRASS to
> perform calculations with the Box Counting Method. The box method is
used
> here to measure the fractal dimension of the spatial and scaling
> distribution of fractures.
> A sequence of grids, each with a different cell size is placed over maps> of fracture traces and the number of cells intersected by the fractures
> is counted.
> We used scanned maps of the fracture traces, imported them into GRASS
and
> tried to run r.reports on the same mapset with varying resolutions. this> did not work. We thought about using r.mapcalc to do some kind of
> neighborhood analysis, but the problem seems to be the varying cell
sizes.
> Is it possible to use r.mapcalc within one location but different
> resolutions of raster maps ? Could it be done with several locations (
> r.mapcalc takes input from location 1 with res 1 and analyzes this grid
> with neighborhood-sizes of location 2 with res 2 and writes the result
to
> location 2 ) ?
> Any comments or ideas would be appreciated !
> Cheers, Michael
> Michael Schulz
> Christoph-Mang-Str.5 Geologisches Institut
> 79100 Freiburg Universitaet Freiburg
> Albertstr. 23b
> 79104 Freiburg
