Well I've never figured out how to strip off CR/LF characters
using sed or awk, however I was able to using dd - a file
conversion utility. If you know the block size of the
records you can strip off the CR/LF by specifying an output
block size 1 byte smaller. For example, the data general
machines used by the USFS typically use a block size of
1024 bytes with a CR/LF character appended. To strip that
off, I used the following command where:
if= the input file, of= the output file,
ibs= input block size, obs= output block size
cbs= conversion block size, conv= conversion type
dd if=in.dem of=out.dem ibs=1025 obs=1024 cbs=1024 conv=block
If you don't know the block size, you might be able to
deduce it using the command od - output dump utility.
For example: od -a in.dem would output the dem file in.dem
a byte at a time interpreted as an ascii character - CR/LF
characters appear as nl (newline). By comparing the byte
addresses where the nl characters appear the block size can
be determined (the addresses are in octal)
Good luck,
Andrew Hertz
hertz@geog.psu.edu
