?at?Jan?10??95?08?34?52?am@bnr.ca>
Reply-To: grassu-list@max.cecer.army.mil
NNTP-Posting-Host: ux1.cso.uiuc.edu
Mime-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Originator: daemon@ux1.cso.uiuc.edu
>Greetings from Idaho !!!
>One of our field offices is trying to get some field boundary and soils
>information to a land owner. They have it on their GRASS GIS system.
>The land owner has software called "CROPSITE" whcih can import data in
>"AGLINK", "SURFER", "MAPSITE", or "ASCII" format. I'm not familiar with
>the first three formats, and I don't know what sort of ASCII format file
>the fourth is.
>Please share any information you may have on exporting data to this software
>Thanks in advance.
>David Hoover
>Manager, CGIS Section
>USDA-NRCS (SCS)
>Idaho State Office
>a16dhoover@attmail.com
>208-334-1525
>David,
I used SURFER years ago to show topology of some small areas. Back then the
file format was a based on a simple x,y,z coordinate system where x=latitude,
y=longitude and z=altitude or some value such as height or amount. These
coordinates were referenced on a general x,y,z=0,0,0 grid. When I was using
this system, I imported it into SURFER from an ASCII text file in columns of
x.
y, and z.
It was all very simple if you had everything as point coordinates.
I have never done this, but you could use v.out.ascii, r.out.ascii or
s.out.ascii. You can
view the manual reference for these commands using g.manual {grass command}.Hope this helps somewhat.
Catherine
Catherine H. Coleman
Natural Resources Branch - USMA
Ph# 914-938-5939 Fax: 914-938-5453
email: yc5763@westpoint-emh2.army.mil
You'll probably want to use r.stats with the -1gz flags to output non-zero
cell values and coordinates as ASCII text. You can pipe this output directly
to awk if you need to modify the format (r.stats also has an option for
defining the field separator character.). Anyway, this will give you x,y, and z
values for each cell. Good luck!
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
