Just tested out the patch, and it works great, solved the problem. I
will forward the patch to Markus, to incorporate it in... It shouldn't
break anything...
--1791007195-269167349-893247433=:778
Content-Type: TEXT/plain; CHARSET=US-ASCIIOn 17 Apr, Richard E Nairn wrote:
> I notice that when I compile the source code that curses doesn't seem
> to be working right. I think that I have the same version that you
> do. When I try and create a new area, it just blanks the screen
> without showing the question...
> Have you run into this problem? I have both curses and ncurses
> installed.. I don't know if it using the wrong lib?
> Richard Nairn
> Geological Survey of Canada
> ** Email ren@spans.gscc.nrcan.gc.ca **
> ** nairnr@cadvision.com **I have had the same problem with ncurses (4.2) an I did the following patch.
Tell me if it is ok for you.
ciao - marco--
Valagussa Marco CRCC s.r.l, via Passerini 2, 20052 Monza (MI) ITALY
Tel. +39.39.387998 FAX +39.39.382115
e-mail: marco@crcc.it
--------------------------------------------------------------------------------1791007195-269167349-893247433=:778
Content-Description: gets.diff*** gets.c.Orig Tue Jul 1 01:59:07 1997
--- gets.c Wed Apr 1 18:32:35 1998
*** 38,39 ****
--- 38,40 ----
+ if ( isatty(1) ) (void)fflush(stdout);
ctrlz = 0;--1791007195-269167349-893247433=:778--
Richard Nairn
