d.3d in GRASS 4.1
We were very impressed with the speed of the new, improved d.3d on GRASS 4.1.
But other less than desirable aspects have been encountered that are
worth noting:
----- Begin Included Message -----
From jesse Fri May 28 11:58:59 1993
Sender: lists-owner@moon.cecer.army.mil.
Reply-To: grassp-list@moon.cecer.army.mil.
Precedence: Bulk
To: greg@terra.cor2.epa.gov
Subject: d.3d
Reply-To: jesse@terra.cor2.epa.gov
Date: Fri, 28 May 1993 11:58:55 -0700
X-Lines: 30
Status: O
Content-Length: 1397
Lines: 34
  d.3d, though faster, is now brain dead.
1) The format of 3dview files is different. It no longer retains information
about erase colour, line colour, or average elevations. This must be
changed EACH time a 3dview file is used.
2) It will over-write an existing 3dview file when it uses an old one.
3) It (still) will not allow me to over-write an existing 3dview file when
I exit d.3d. So it can do what it will not allow me to do.
4) It will draw into the full screen frame, even it a sub frame is active.
5) It will do item 4 only AFTER the first time an old 3dview file is used.
Then there is different behaviour between the first use of a 3dview file
from all following uses. This is difficult to reproduce.
  I have not tried it on an lat/long projections yet, so I do not know
if it is still broken in that way.
  Speed is not everything.
R Jesse Chaney Internet: jesse@terra.cor2.epa.gov
Environmental Research Lab Internet: jchaney@research.cs.orst.edu
200 SW 35th Street UUCP: hplabs!hp-pcd!orstcs!jchaney
Oregon State University Phone: (503) 754-4497
Corvallis, Oregon 97333 USA FAX: (503) 754-4338
----- End Included Message -----
