d.3d
Gail Goulet (goulet@vulcan1.hac.com) writes on 13 Jan 94:
I've been working with the 4.1 version of d.3d to display dted data. I am
interested in plotting vector data (3d) on this display. Has any work been
done in this area?
Another possibility is to turn your vector data into a raster layer using the
CELL driver. The CELL driver replaces your normal graphics driver (x0, x1, etc.)
and simply records anything that you display (using the "d." commands) to a
single raster layer, which can then be used with d.3d . Kind of a round-about
way, but it works. Following are detailed instructions:
Thanks to a posting from Ronald Wiemer on grassu-list, I have finally figured
out how to use the CELL driver in GRASS. This enables you to capture anything
that you would normally display on a GRASS monitor (vectors, sites, labels,
legends, etc.) in a single GRASS raster layer. Here's how:
1) define the height and width of the CELL driver in pixels:
   setenv GRASS_WIDTH 1000 (or some other number)
   setenv GRASS_HEIGHT 1000 (ditto)
2) start the CELL driver:
   d.mon start=CELL
3) display your desired map layers, etc., just as you would on a monitor (you
don't get to see any of this!). All of the "d." commands work as usual. It may
help to compose the map on a regular GRASS monitor, and then save the commands
as a script, which can then be run with the CELL driver selected.
4) stop the CELL driver:
   d.mon stop=CELL
5) reselect your old GRASS monitor:
   d.mon select=x1 (or whatever you were running)
6) set your region to the new raster file created by the CELL driver; it will
always be called D_cell:
   g.region rast=D_cell
   d.erase
7) You can now display the raster map (d.rast D_cell), or use p.map or
ps.map to paint it. Be aware of the resolution of the output device, whether
it be your GRASS monitor, laser printer, or color printer, as compared to the
resolution that you chose for your CELL raster map. THIS IS IMPORTANT!!
Good luck! If you are having problems with this, get in touch with me.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
