d.mon:"can not allocate any read/write color cells"
Thanks a lot for your help. I installed the g77 (which is not
installed along with gcc by default as I thought) and all
compilation prolems but one
are solved. The remaining one is:
/usr/local/grass42/src421/src.related/rim
  make -f OBJ.linux/make.rules
run.setup
make: run.setup: Command not found
make: *** [rim] Error 127
GISGEN failure at STEP: src.related/rim
Rim is not (by now) critical for us, though, so I went on with the
installation without it.
The real problem is that I get the following error when runing d.mon, and
this
seems more serious:
[root@localhost bin]# d.mon start=x0 &
[1] 22540
[root@localhost bin]# can not allocate any read/write color cells
and the monitor window never comes up.
I had problems at configuring X because my Matrox card was not included
in the RedHat list of supported hardware, so I got a driver from the
Matrox site (actually it is a SuSe driver) along with the newer version of
XFree86 (Release 3.3.2) and edited the XF86Config file.May be what I
finally have
is not compatible with Grass?
Are there resolutions that could be incompatible with Grass 4.1.2?
Thanks
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
