Forwarded message:
Message-Id: <9406150620.AA05848@imt.ntou.edu.tw>
Sender: grass-lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Subject: d.monHi!
I run the d.mon start=x1 and display "Graphics dirver [x1] is a already running",but cann't display the x1 monitor.
Can you tell me how can I do.
Thanks in advance.
Just try d.mon select=x1 if the monitor is visible, or stop=x1.
Otherwise--
Use the UNIX ps command to find the process number of the x1 monitor,
then use the kill command to stop the process. x1 should then be able to
be started.
