d.mon - Problem
Kym Lenkus writes:
(lines deleted)
  I get the following errors after I type :
    d.mon
    1 for start graphics monitor
            x0 for xdriver
Graphics driver [x0] started
ERROR: region for current mapset is not set
     run "g.region"
Problem selecting x0. will try once more.
First, set your region by typing "g.region rast=raster_layer_name" (try using
elevation.dem or equiv if you are in spearfish location). This will create
the $LOCATION/WIND file that Darrell mentioned. If this command works, and
d.mon still doesn't, than you have more serious problems!
Good luck!
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
