d.mon - program
Hello ,
I did a installation of grass4.0 on Sun IPX machine - & have no problems.
The problem is comming when starting d.mon program - there is no monitor
on the list and what I should write for graphic monitor name ???
I found a catalogue MONITOR - it is empty ! :-o .
Can anybody help me - maybe it is not a difficult problem.
Thanks in advance
Peter Sincak - Technical University of Kosice - Slovakia
Check the monitorcap file is GISBASE/src/etc. You need to uncomment the lines
corresponding to the monitors you wish to be able to access.
James A. Farley Technical Director, CAST/NCRI-SW
      12 Ozark Hall, Univ. of Arkansas
jim@moray.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
